Dforce Hair Going Through Body
I am trying to simulate the following:
SOFT CLASSIC HAIR with Dforce for Genesis 8 and 8.1 Females available here https://www.daz3d.com/soft-classic-hair-with-dforce-for-genesis-8-and-81-females
But the hair keeps intersecting my character when the sim is complete. Hair looks ok at start, all behind the character. I've tried adding static dforce to body and arms which seems to help but doesn't fix. See pictures. Tried no Memorized pose and with memorized pose. Seemed to work previously with this character, Dokota, but not now in this pose https://www.daz3d.com/cb-dakota-hd-for-genesis-81-females
403 x 399 - 245K
448 x 417 - 451K
  • crosswindcrosswind Posts: 7,828
    Select the figure, check if "Visible in Simulation" is turned off...
  • Also, you may want to check the simulation "quality" -- I'm not sure what it's actually called in the Simulation pane -- and make sure it's set to Better or Best.
    Sometimes, if the quality is set to "Good", the simulation isn't as fine-grained, so the simulated mesh can fall through other meshes.
