G9 morphs problem (with DAZ morphs !?)
Hi, I have G9 and G9 characters installed, but I pretty much never really used them, so, I just noticed today a problem I have.
I loaded a G9 character, and it when it loaded, it had pre-dialed the morphs for another G9 character, and a bunch of other morphs.
   I uninstalled the parasitic character, but that did not really solve the whole problem, because I realised the other morphs that were parasitic, i.e. loading even with the base and any other character.
   The problem is that those morphs are body_bs_ProportionArmsLength.dsf, body_bs_ProportionHeight.dsf, body_bs_ProportionLegsLength.dsf, body_bs_ProportionChestDepth.dsf,body_ctrl_ProportionHandSize.dsf, /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Proportion/body_ctrl_ProportionHandSizeL_scl.dsf, /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Proportion/body_ctrl_ProportionHandSizeR_scl.dsf, head_ctrl_ProportionHeadSize_scl.dsf.
   In other words, the other parasitic morphs are actually morphs that are part of the Genesis 9 Starter essentials ("1 of 2", to be precise) - whenever I try to load a character, or even the base G9 character, they load with some values, instead of being at zero. I tried to see if there was an update of the package (DIM seemed to indicate one) download it, and then, updated the installation,but that did not solve the problem.
     Anybody had a similar problem, and if yes, how did you solve it ? For now I did a work around using Turbo Loader to disable those morphs, but it seems absurd, considering they are part of the Genesis 9 starter (so, official DAZ stuff).
   Thanks
  • crosswindcrosswind Posts: 7,828
    Those "....propotion...." morphs must've been automatically dialed by controlling morphs from a certain character. You should identify that character first. In Parameters pane, Show Hidden Properties... select Currently Used and carefully check the dialed properties.
    There might be a character's morph with 100% value, and probably in grey color...
