DS 4.22 manual install time?
I have downloaded the latest Daz Studio install files as they never install properly via the DIM.
The install always did take its own sweet time but it has been hours and it is still installing.
After how many hours should one stop the install process and try again?
  • fixmypcmikefixmypcmike Posts: 19,598
    Is it waiting for a UAC prompt or a security program prompt?
  • MouserMouser Posts: 675
    Basicly
    downloaded exe file
    Clicked the exe
    Selected the C drive for the application
    Selected the F drive for content
    As I have done before
    And then its been like this for hours:
    652 x 382 - 31K
    See if the firewall is blocking it.
    Okay its listed on my firewall as unrecognised.
    Changed firewall
    Still stuck on install
    aborted install
    Restarted
    some kind of postgres Error:
    502 x 125 - 26K
    Some security program is blocking the file from being extracted.
    No firewall is off.
    Still postgres error
    If the file isn't being exracted, it's not the firewall, it must be UAC or antivirus/antimalware
    Okay all security, virus checker & firewall are all off.
    No change, still getting error.
    It's trying to install to the F drive -- can you set the content locations outside of Program Files?
    Thats where the previous version is.
    Program on C drive
    Content on F drive
    This is due to C drivew not having enough space
    The error message shows the file couldn't be extracted to F:\Program Files\... -- is that where you have content installled?
    Yes
    I think the issue must be with the main application which makes no sense whatsoever as that is where the previous versions are installed.
    I will try another install location.
    Right back where I started, installing again.
    Did some investigating and apparently this issue has been popping up since v4.9 at least 8 years ago.
    My current DS setup is mangled so Its looking like I'm going to have to clean house & start from scratch.
