Selecting Surface with the same name
Hello, I have imported an FBX model from Sketchup and I want to apply materials to it in Daz. However, since the faces are separated, it's a huge task to select each face individually. I was wondering if there is an easier way, that would help me in selecting all faces with the same names (as they all had the same material in Sketchup, hence their names are the same) at once, or even linking the material of those faces so that I don't have to select each one individually. Thank you.
If in Surface pane, Ctrl + Select the surfaces... if with Geometry Editor (Alt + Shift + G), in Tool Settings pane, click "+" sign to add Surfaces / Face Groups to the selction. If there's no Face Group, better create a Face Group for the surfaces that have the same name.
Thank you. I thought there might be a simpler way to accomplish this without having to individually select each surface.
I don't know whether this will help you, but it sounds similar to what you want to do: Search and Select Surfaces thread
I didn't know there's a such a useful script. Thanks @MelanieL !![yes yes](https://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/thumbs_up.png)
Thank you Litterary what I needed
