Animating a Drum With MIDI
![Keiron](https://delorean.daz3d.com/forums/uploads/userpics/383/n8QY0QVL4LQ8R.jpg)
Hi
I've been busy making a Excel File using Visual Basic to help with MIDI animation "work in progress"
If you would like to try it then Email me at [email protected] so I can send you the file
It uses Excel 2010 for now with Visual Basic to do the hard work
It checks the MIDI file and allows you to make changes
The main purpose is to move the Drum Note off to a new location to give the Animator more time as the Drum MIDI note On and note Off are really close together
It also tidies up the MIDI file for Animation purpose
I have created a number of Videos on How to use it along with Part 1-8 of Animating a Drum kit
Videos How to use MIDI helper
Using MIDI Helper to check MIDI times an move the Notes
Using MIDI Helper to check MIDI times an move the Notes using ch10 using sliders
Using MIDI Helper to check MIDI times an move the Notes using ch10 Auto
Using MIDI Helper to check clashes on ch10 drums
Animating a Drum using Daz Studio, Keirons MIDIhelper with the modified MIDI file and Casuals MIDIload
Animating the right hand drum stick for the MIDI Hiatt patten and MIDI Bass drum pattern
Setting the Drum stick pivot points
Animating the right hand drum stick for the MIDI Snare drum Rim Shot pattern
Animating the right hand drum stick for the MIDI Snare drum pattern
Animating the left hand drum stick with the MIDI Ride 1 pattern
Setting crash 2 and adding the crash2 MIDI pattern
Setting up the right hand drum stick for the crash2
Modifying right hand drum stick and the crash2 animation
Adding Movement to the snare drum and tom toms
Changing the surfaces on the drum kit and adding Glossiness
Setting up the right hand drum stick for the Tom Tom Hi & Clash2 using the Tom Tom pattern
Setting the left hand stick for the Ride Bell
Lighting and Rendering out you Video
06/12/2015 Added further tutorial videos on how to Animate a Drum Prop using Daz Studio 4.8, MIDIload and a converted MIDI text file using MIDI helper
08/12/2015 New Animating a Drum with MIDI training Video's added
Hi
The link below is a video with the completed Generation 3 Daz figure playing the drums
A few errors to deal with before importing into the band scene, there is an issue when parenting some things, if you make things constant after parenting the object it reverts back to linear? . I've asked Daz to take a look at that
Have a lovely Christmas and Happy New year
Made using Daz Studio ver 4.9 Beta, rendered using Open GL
Daz Genesis 3 figure
Outfit Jackyline for Genesis 3 Female(s)
Jackyline Outfit Textures
Rama Drum Kit from Daz 3d.com Daz Originals Ravnheart
Midi Helper Ver 2.2 Beta By Keiron
Midi Load 3.1 Beta By Casual
Well finally after a lot of hard work the drums are playing in sync and the Generation 3 figure is playing the Drums
https://youtu.be/aVFTgxpOq4g
I had an issue with the Generation 3 model's fingers as they kept changing after they were Posed, the Scene saved and then the Scene reloaded?
I then tried Daz Studio 4.9 Beta and all was well, but I had to redo all the Generation 3 animation again
Still working on making her to make her a bit more life like, she is still a bit Robotic LOL
Other issues I came across were as follows
1. The lights changed in an odd manor if I added more than one keyframe occurence of the same light to the time line
2. If I parented an object that had been set to a constant value, then it set all the values on that time line to Linear, so this time I didn't parent the hands to the drum sticks or the Camera to anything
It is very, relaxing and cool![yes yes](http://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/thumbs_up.png)
Hi JaguarElla
Thank you, I'm currently re working on the Keyboard and Piano, so I hope to post them soon
VERY COOL Idea using VB to create animations movements.. I use midi-master for my RMS paino /Keyboard to move recordings to my PC. I wonder if i could adapt technique to using Midi-master with VB. I seen where your using Excel 2010. what version of visual basics are you using? .. It really looks awesome & super great idea.![smiley smiley](http://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/regular_smile.png)
Hi Ivy
The Visual Basic is already in Excel you just need to enable it
http://www.techonthenet.com/excel/macros/visual_basic_editor2010.php
I bought a book on Excel using VB from Amazon and spent a few hours bringing my VB up to speed, im not the best at VB although the Idea worked OK
I created the song and saved it on the Piano Keyboard, then used Samplitude from Magix to record the MIDI and Wave file from the Keyboard
Kindest wishes
Keiron
Thanks for the info I going to have to give this a try I found a download for amplitude Music Studio http://www.magix.com/us/free-download/samplitude-music-studio/ Is that what you are using?
I have 3 different versions of MS office the first copy office pro 2008 which came with my windows7 pro. running VB 2008, which I do not use anymore. I have office 2010 that has vb 4.5 & my latest copy of windows office 2013 that has vb in it.. But I also have a Visual basic 6 standlone editor I'm pretty good with Visual basics using asp.net. C# & C+++ programing I work with it daily. So I am going to defiantly have to try this. Have to tried using motion captures and importing into VB? I wonder how that would work.. though I guess you properly would need to get the Motion capture in to some kind code form for it would work..
Hi Ivy
I'm using Samplitude Music Studio 2015
Not only will it allow you to record music, but you can also create your own using Samples too, lots of fun
I'll release the VB program Excel sheet soon, but I've some other few add ins to make first.
PS I got Microsoft Visual basic 2012 free from their site
The link below is a Tutorial showing a method you can use to sync a MIDI file to the HiHat and then Animate the Daz Generation Figures foot to the HIhat
Hi
I've now completed MIDI helper ver 2.5
I have added the ability to use two different drum kits, defauts are CVP605 and General MIDI
I've also added a voice section so you can see if there are any voice changes occuring this uses the General MIDI voices
As before you need a fairly good Processor for this, i've used the 4 Gig I7 quad with 16 gig memory, although you shoudn't need any where near that amout of Memory
You can download it from here unzipped is around 62 meg, Zipped is around 11 meg
Please note this is for Microsoft Excel 2016, Apologies to MAC users
http:/keiron.me.uk/download/MIDI_Helper_ver_2.4.xlsb
http:/keiron.me.uk/download/MIDI_Helper_ver_2.4.zip
Added extra Drum selections 01/02/2016
http:/keiron.me.uk/download/MIDI_Helper_ver_2.5.xlsb
http:/keiron.me.uk/download/MIDI_Helper_ver_2.5.zip
it's an 2010 Excel sheet, you need to allow macro's
I've checked it with AVG and Windows AV but please run you own Virus protection
I'm not the best or fastest Visual Basic programmer, so I'm sure there are faster ways of doing things, but it gets the job done
Please copy and paste the link into you browser if needed
Added MIDi helper 2.5
Extra Drum instrument definitions added
