Question on pinning clothing.
The title may be confusing, I wasn't sure how to describe my problem. I have the Flow outfit from Art Tailor and when I pose the character the "cuff or bell bottom" follows or is pinned to the foot. This deforms the botom of the pants when it is a high heel pose. Also using D-force the cuff is pinned to the foot even though it is not touching it. I have found many renders using the outfit where this is not happening so I am doing something wrong, I just don't know what. I have tried several poses from different vendors and all had same results. Flat foot poses do the same thing, its not as noticable because the foot isn't bent like a high heel pose, but it is still pinned to the foot. Any insight would be very appreiciated, I really like the outfit and don't want to give up on it.
  • crosswindcrosswind Posts: 7,828
    I'm not so sure how the issue looks...better post a screenshot. But there're some Material Presets will wrongly set the properties on dyanamic surfaces. Go to Surfaces pane, select all Ruffle surfaces, make sure Dynamics Strength is 1.00.
    2031 x 1399 - 567K
    Thank you for the reply but it did not seem to help. It doesn't look like you have the problem. Maybe I should download the outfit again, that is the only think I can think of. I have tried everything that I could think of.
    3860 x 2160 - 2M
    Oh, I see it. That's the pJCM issue, the corrective morph - "pJCMFootDwn_75_L/R" on the pants when foot rotates... Usually the author fixes pJCMs... but since this is a set of dForce outfit, I presume ArtTailor decided not to fix them other than leaving it for the users to simulate.
    You may just simulate with "Start Bones from Memorized Pose...", that'll be fine.
    2560 x 1400 - 701K
    2560 x 1400 - 683K
    Yup, worked like a charm...Thank You!!!
