Serpent Maiden poses downgraded?
It seems that this product
https://www.daz3d.com/serpent-maiden-poses-for-genesis-81-female-and-morphing-python
has been halved because it was sold as poses for 8 and 8.1 - now there is no more the part for 8 but I'm sure it was there because I had used it and also all the promo images are made with an 8 model. I just wanted to know if they changed it by taking away poses from the original product? indecision
  • crosswindcrosswind Posts: 6,987
    No change... There've been only Pose Presets for G8.1F but they're applicable for G8F..
  • BellaBella Posts: 439
    Really? When I select the 8 model they don't appear in the smart content ... I will try, thank you
    Oh ! If you use Filter by Context, that won't work, as the Pose Presets are only defined with Compatibility for G8.1F in metadata. You just select G8F, then apply pose preset from the product. That'll be fine.
    If you do need them for Filter by Context, just Edit Metadata to add Compatibility of G8F... as attached.
    1068 x 842 - 72K
    1398 x 1115 - 160K
    1398 x 1115 - 115K
    Thank you very much for the help, I succeeded in it, I must have done so even before but it’s been a couple of years ago and I didn’t remember at all, thank you again and also for the metadata information ! smiley
