Daz Studio crashes when the render begins
desfendesfen Posts: 75
I initiate the render, and always after just a short while, Daz Studio just crashes, closes out, and there's no error pop-up. I'm using the Raytracer Final scripted pathtracer rendering, and I've posted my error log
txt
txt
log.txt
52K
Post edited by desfen on
  • NinefoldNinefold Posts: 256
    Is there an outoftouch hair product in your scene? Going to the Surfaces pane and removing the maps from the transmitted color channel of all of its materials will fix this crash, if so.
  • Richard HaseltineRichard Haseltine Posts: 100,948
    This is 3delight, not iray, so the out of Touch hair issue is not relvant 9and it appears to be just a scene, judging by what loads).
    Oh, pardon me, I didn't realize.
  • desfendesfen Posts: 75
    yeah 3Delight it is as i've also been having problems with Iray
  • Sven DullahSven Dullah Posts: 7,621
    edited January 29
    I'm afraid this is not something I can help with, as I know very little about interpreting lines of code. But I understand that much that it performs the tdl.make process, which should be the very last pre-processing step before rendering starts? And it just shuts down? Any other hints in there? The fact there is no error message involved at that stage may indicate something to someone that actually understands that stuff??
    Furthermore I'm on Mac and DS 4.20, so...
    Post edited by Sven Dullah on
    edited January 29
    That was the ShadedHaven conversion scene I shared? Have you tried rendering just one simple object, a plane with 1 division or similar, without lights or environment spheres? Or tried loading that scene and delete the Pergola, save under a new name and render?  Of course using the Raytracer Final script?
    TDL Make runs (or used to) in the background, it makes multi-res versions of the maps.
    hmm that sounds interesting yeah
