Genesis 8: Can't find basic controls, sliders not working, help needed
Hi, I'm a newbie.
I can't find a slider to bend just one knee of a Genesis 8 figure.
I would expect Flex Quad Left and Flex Quad Right to do that, but these two sliders have no effect.
Both Flex Glute Clench sliders have no effect either.
Neither can I find a slider to bend elbows.
Can someone help? Thanks in advance.
J. Oxtrap.
  • crosswindcrosswind Posts: 7,860
    You want to have a Shin Bend. Alt + Shift + U, select Left Shin of the figure, in Parameters pane, dial Bend.
    Flex Quad Left / Right properties are automatically triggered by Shin Bend with negative values. But they'll still work if you manually dial them..
    As for bending elbows, you want to have a Forearm Bend, select Left Forearm, then Bend.
    2560 x 1400 - 383K
    2560 x 1400 - 392K
  • Thanks a lot!
    How do you get the vertical tabs to be displayed small and neatly next to each other? In my version of Daz3D they are so big and so decorated that I must scroll up and down to discover them :-(
    1024 x 779 - 300K
    1129 x 901 - 106K
    I just use a Style named "Highway". You can go to: Window - Style - Select Style, to try the style and others, see which one you like.
    862 x 548 - 58K
    712 x 553 - 57K
