Help with direction of ies files?
in The Commons
I've been trying to get familiar with the different ways to light my scene using iray and have been experimenting with ies files. But I have a small issue. If I want "light" to come from a window on the left wall (for example) the ies file doesn't work. I have found some "downward" ies files and a few "left facing" ones, even some upward (floor) ones but I haven't found any that point "right" and I can't figure out how to adjust the ones I have when the "light" will be coming from something that doesn't or can't be rotated (like a wall or a window). Is there some way to edit the file to change the direction it points? Or is there a parameter in Daz Studio that will rotate the file? Thanks.
Lights from IES goes in (minus) Z-direction of the object you emit from (Thats why I created two emitters for my Emission Profile Master product. The reason is that Iray internally uses Z for vertical.
Totte iss aying that the lights are set to shine along the Z axis. You need to rotate the item they are applied to, having created it facing Z forwards (assuming ti is a promitive).
I created a plane with Z forward, but I had to rotate it 180 degree, to get it right.
Edit: which corresponds to the axis orientation in blender.
Sorry, Z backwards was what I should have said
Minus Z that is :P
Ah! I see. Okay, thanks, guys!
