G9 - How to change Iray Uber Shader to PBR shader skin?
G9 - How to change Iray Shader to PBR (MDL) shader skin?
Post edited by James on
Iray Uber is PBR, PBR Skin is specifically for skin - depending on the material set up you may not have the right maps to take full advantage of PBR skin. Is this a geenral question or is it related to a specific character set?
If what you want is to convert characters using Iray Uber shader to PBR skin shader, this utility can help: https://www.daz3d.com/1-click-pbrskin
Commercial thread about it: https://www.daz3d.com/forums/discussion/640976/released-1-click-pbrskin-commercial
Simplest answer is to select the surfaces you want changed and apply SkinPBR shader.
But after that you will have to enable all the relevant channels.
