Downtown NY Living Room not loading in at all
^An error has occured see log file
2024-02-06 22:37:38.305 [INFO] :: Prepare asset load (open): /Environments/Architecture/Downtown NY Living Room/Downtown NY Living Room.duf
2024-02-06 22:37:38.305 [INFO] :: Locking viewport redraw...
2024-02-06 22:37:38.305 [INFO] :: Viewport redraw locked.
2024-02-06 22:37:38.345 [VERBOSE] :: Native format content directories: 2
2024-02-06 22:37:38.345 [VERBOSE] :: Poser format content directories: 2
2024-02-06 22:37:38.345 [VERBOSE] :: Other import format content directories: 0
2024-02-06 22:37:38.345 [INFO] :: Begin asset load (open): /Environments/Architecture/Downtown NY Living Room/Downtown NY Living Room.duf
2024-02-06 22:37:38.345 [INFO] :: C:/Users//OneDrive/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_67361/environments/architecture/downtown ny living room/downtown ny living room.duf (1,1): Syntax error - expected '{' or '['
2024-02-06 22:37:38.345 [WARNING] :: Error loading asset: C:/Users//Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_67361/environments/architecture/downtown ny living room/downtown ny living room.duf
Operation failed
2024-02-06 22:37:38.385 [INFO] :: Unlocking viewport redraw...
2024-02-06 22:37:38.385 [INFO] :: Viewport redraw unlocked.
Any ideas on how to resolve?
" // "  my name between so redacted
Ither products seem to load fine, not sure what gives with this one.....
  • NorthOf45NorthOf45 Posts: 5,548
    edited February 2024
    It seems the file "downtown ny living room.duf" has been truncated, or corrupted, most likely from a bad Connect download or decryption. Try to re-install the product from a fresh copy.
    Post edited by NorthOf45 on
  • crosswindcrosswind Posts: 7,988
    No issue on my side... Again, OneDrive + Daz Connect turned into the culprit on your side. And again, personally suggest no-go for OneDrive, no-go for Daz Connect...
    In general, there should be a warning stickied on the forums "Never install any content to C:\Users\"
  • Hmmm good to know. Will have to full reinstall with different folder. When I set up daz I didn't realize it was in the one drive structure. I wonder if that's why it's a bit slow to load in. My 3P content takes 1/4 or less time to load in, I just assume it was larger files.
  • It looks as if the files are not decrypting properly - it isn't finding a valid opening character. Please report this to support, but in the meantime if you download the product zip and copy the files ands folders from inside the Content folder in the zip into the C:/Users//OneDrive/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_67361/ folder (you should be asked if you want to merge the folders and overwrite the files - say yes) it should load OK.
