I have done it. Female Draenei have been made!
I did not make a draenei character for use by others. BUT have the recipie to make them.
1. Genesis 8 character (no other will work)
2. Succubus pack for Genesis 8 (https://www.daz3d.com/succubus-pack-for-genesis-8)
3. Tara for Genesis 8 or any other horn pack
4. Bone shaders (any will do)
5. Skin builder for Genesis 8 (https://www.daz3d.com/skin-builder-8-for-genesis-8-females)
6. EJ Fantasy Races Creator and Morphs for Genesis 8 Female(s) and Male(s) (I cannot find this on the store anymore, the succubus hooves will work, just not as well and not as customizable)
Step 1: Add a Genesis 8 Body, I recommend the plain one, you can morph it later
Step 2: Add the Succubus tail
Step 3: Add horns of your choosing
Step 4: If have have EJ Fantasy Races Creator and Morphs for Genesis 8 Female(s) and Male(s), Morph the legs into hooves shape 1
Step 5: With Geometery Editor, select ONLY the hooves from what is morphed and create a new surface named "Hooves"
Step 6: Apply the Bone shader of your choice (you will color this later to match your asthetic
Step 7: With Skin builder. apply the color skin you would like, (white, blue, purple, etc)
Step 8: Make any adustments you want to the tone before closing Skin builder
Step 9: In the Surfaces tab for your Genesis 8 character, select the pupils, sclara, eye moisture, irises, and cornea.
Step 10: Click the Shaders drop down, locate "Emissive" and apply it
Step 11: Chose your base color and emissive color. You will need to play with the level. I find lm/cm2 and 100 lumens works fairly well for most applications, Also the Tempurature will vary. I find higher for purple eyes, colder for bluer eyes and for yellows whiteish, use around 6000-7000K
Step 12: Select Genesis 8 character, go back to the surfaces tab and select the "Legs" surface
Step 13: Copy the Base color
Step 14: Select the "Legs" subsurface of the "SB Tail G8" surface
Step 15: Paste the Base color you copied from step 13. This will copy over all of the other required settings as well
Step 16: Go into Geometry Editor and delete the tail blade. Fun fact I found... if you doulbe-click a section it will select all the surfaces on that plane. SOO MUCH FASTER.
Step 17: Add hair if desired
Step 18: Select the Shaping tab > Ears section (if you have EJ Fantasy Races Creator and Morphs for Genesis 8 Female(s) and Male(s) or any elf character or similar)
Step 19: Alter the ears to match your asthetic.
Steo 20: Go into "Hands" section and use the "Longer Nails" and other nail morphs as needed to elongate the nails into claws.
Step 21: color the hooves and horns to desired look.
Step 22: (Optional): Go into the facial riggings and play with the nose, cheek and chin, resize them and/or move them as needed for you look. Also make use of the EJ Fantasy Races Creator and Morphs for Genesis 8 Female(s) and Male(s) and other morphs for the head in the settings
Step 23 (Optional): Add Nail, and Makeup materials and shaders as required.
If all goes well you have a Draenei.
Emma & Jordi have a Gumroad store now, so the Fantasy Races set the OP mentioned might be available there.
Nice one, but it's still missing one piece, the tentacle dreadlock on the head/neck but it is a great job^^
