Problem applying custom eyelashes to figure
![HellcatF6F](https://delorean.daz3d.com/forums/uploads/userpics/730/n0BBE312C130D.png)
I made a set of fibermesh eyelashes in Blender, then used the Transfer Utility to transfer the properties of the Genesis 8.1 Female Eyelashes to mine. It works, but when G8.1F's eyes are closed, the lash fibers get deformed. How do I fix this? Is there an alternate way of fitting the eyelashes?
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/13/e014efcd1b2df33aba2863318f4580.jpg)
2560 x 1440 - 573K
You probably need to edit the weight-maps for the lashes on the eyelid bone (I can't recall its name) or add a custom close morph or both - projection, of morphs when they are applied or joint weights with Transfer tool, is fairly simple-minded adn does not cope well with mesh that is far from the skin, especially if it is angled rather than projecting straight out.
