Changing metadata information manually
Hello all,
I'm having trouble uninstalling assets from Daz either within the program or usim DIM/DAZ Central because the metadata is pointing to the wrong device drive (an old one). Is it possible to manually modify it? I've already edited the Content Directory Manager in Edit->Preferences but it didn't work.
Thank you.
  • SofaCitizenSofaCitizen Posts: 1,893
    You need to uninstall it using the same method you installed it with. If you used DIM (or Central) then you will need to uninstall with DIM. If there is a path issue between where DIM thinks things are and where they actually are you'd probably need to hand-edit the DIM manifest file for the product.
