Frieren hair and maybe outfit?
![Diaspora](https://secure.gravatar.com/avatar/2dec2a94e179c2ccc3b7a3f11f7f7b4d?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F2dec2a94e179c2ccc3b7a3f11f7f7b4d_100.png)
Hello! Any suggestions on products to get Frieren's hair?
And how about the outfit? I'm guessing the outfit's a much taller order, that 'double bell' sort of look is quite distinctive, but if I can at least get the earrings and the hair then maybe I could kitbash the outfit on my own.
![](https://delorean.daz3d.com/forums/uploads/thumbnails/FileUpload/49/ce82985420cb01a0dd93bb845e71c3.jpg)
386 x 718 - 54K
For the hair, you could start with Long Pigtail Anime Hair, maybe keep the pigtails and replace everything else with something middle-parted. If you're looking for something a bit more realistic, Kanade Hair might do. You could use the cloak from dForce Stylish Cleric over a more appropriate tunic, and I'll scroll through my library to see if anything fits.
Kanade Hair is damn near perfect! And wow, the stylish cleric outfit is actually nearly spot on!
Wow, I guess that's the power of such an enormous and diverse library.
Thank you!
Lady Littlefox's Kinley Hair is also quite similar to this character's hairstyle. It's dForce, which might be a plus or a minus for you.
I actually didn't even need to check my library to find those. I knew the second I saw your image what would work, and only needed to look them up to verify the names and get links.
I really appreciate someone with such an encyclopedic knowledge finding my post so soon.
