Fixing pants on waistline
So for a few of the pants I've purchased, either directly on Daz or other vendors, I've noticed a problem with them sitting too low. Instead of the waist being up closer to the belly button (like most people wear), they're sitting too low across the hips. Is there a way to fix this in Daz directly, or do I have to take the model into Blender and fix it? I imagine that would entail having to redo weight painting as well to account for the movement, and since I'm a nincompoop at it, any way to possibly avoid this would be nice.
  • crosswindcrosswind Posts: 8,122
    That depends... As for "mesh pants", mostly it results from the design of "low waist" which turns out to be a geometry issue rather than a weight issue, i.e. you just need to tweak the geometry. As a Blender user, I surely suggest you go for tweaking the pants in Blender. Or if you own Mesh Grabber, you can just do it in DS and create a "high waist" morph as you wish... The screenshots show an example of a "fixed morph" I did in Blender.
    As for "geoshell pants", I'm afraid you have to retouch the texture map(s)...
    2023 x 1315 - 1M
    2026 x 1315 - 1M
