Model-Room mesh render display question
![Fettbemme](https://delorean.daz3d.com/forums/uploads/userpics/603/nMAM5YLZ453B7.jpg)
Is there a way to display without vertices but only faces?
default setting is, that you can select everything and everything is displayed if you use it or not (Faces, Edges, Vertices)
I am not sure about a display mode that shows only faces. The display modes along the top of the modeler area. But, the good news is that you are able to set the selection to only faces. The selection mode is in the upper right of the right side properties tray. The furthest to the right sets to select by face (polygon).
I like to get rid of the verties being displayed at all times
