CPU and Daz Versions?
DekeDeke Posts: 1,632
I'm looking for a used PC to stuff with as many cuda cores as I can afford. Will Daz run on any CPU?
  • Matt_CastleMatt_Castle Posts: 2,674
    It should run on any reasonably modern CPU, but do bear in mind that things like loading figures, posing figures and mesh smoothing use the CPU (and thus CPU performance can have a big impact on things like dForce simulations, as even though the GPU is doing the simulation, it's the CPU that has to update all the posing for each tick of the simulation).
    So I wouldn't skimp too heavily on it. With DS 4, multi-threading isn't much of a consideration (the code base is old enough that large scale multi-threading wasn't really done when they built the foundations), so good per-core performance is currently what's relevant for that, but hopefully DS5 will allow better use of multiple cores.
  • ed3Ded3D Posts: 2,295
    And  Dell  has  Refurbished  deals  Some pretty good ones  +   worth look  just  because  +   Thanx
