Face Transfer 2 Error
in The Commons
Just started getting the attached error message when using Face Transfer 2. Prior to this is worked perfectly. I tried using it with a Genesis 9 figure and Victoria 9 as well as different pictures. I get the same error message twice, click ok, and the face loads in.
I did install a Daz update for the Genesis starter pack prior to this so I'm not sure if that has something to do with it. Anyone else having this problem?
2559 x 1393 - 2M
How did you instal the Genesis 9 Starter essentials? I just tried and received no error in generating or saving the face.
I used DIM
I am encountering the same error and also installed Genesis 9 starter essentials through DIM
I used Connect (installed through Daz Studio) and just had it isntall the update, rather than reinstalling the whole product - that may be the difference.
Might have something to do with missing textures?
https://www.daz3d.com/forums/discussion/677561/gen-9-essentials-update-missing-eye-textures#latest
I am glad I am not the only one that encountered this error. When I experienced this error, the skin texture of the figure based on FT2 is very very very dark.
I noticed that there is an update to G9 essentials dated 13 March 2024, when I checked DIM earlier today. After DIM has finished installing the update, I still encounter the same error. I have already submitted a help ticket.
I think it definitely has something to do with the new update for the starter essentials pack. Face Transfer was working flawlessly prior to doing the update.
There is a fresh update which says it fixes this issue.
Okay thanks :-)
Thanks!
Dear Richard,
Thank you for the information. I noticed that the last update through DIM is dated 13 March 2024. However, I still experience the same error.
Same here
Sorry, I was getting my threads muddled - the fix is for the missing eye textures.
The missing Face Transfer issue is apprantly in the process of being fixed.
There is a sample script showing how to use alternative textures here http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/specific_ui/appsettings_facetransfer/start
I noticed that there is an Update for G9 essentials when I check on DIM. After appling the updates, I no longer experience the error message.
