Exaggerated one-click expressions for G8 female
For certain products, when I apply a one-click facial expression, it results in an awfully ugly exaggerated version of the expression. Same thing happens if I crank the expression's dial to 100%. There's also a problem with the tongue when it is part of the expression. Cranking the dial to only 50% does not fix the problem. For example, for the Wink expression in Z Reckless, 100% makes the mouth hugely opened, while 50% is a better mouth but the winking eye is only halfway shut. This has happened with at least 3 products from different vendors:
Vintage Glamour Poses for Genesis 8 Female - 3D Sugar
Playful Pin-Up Posed and Expressions for Genesis 8 Female - Capsces Digital Inc
Z Reckless - Dialable and One-Click Expressions for Victoria 8 - Zeddicus
817 x 505 - 449K
  • Richard HaseltineRichard Haseltine Posts: 102,318
    Are theer any expressions already applied if you zero the one you are trying to apply?
    Do you have "AFE - Real Female HD Expressions for Genesis 8 Female(s)" installed and active?
    https://www.daz3d.com/afe--real-female-hd-expressions-for-genesis-8-females
  • aminn2aminn2 Posts: 31
    I do have AFE - Real Female HD Expressions installed, but I haven't used it in a long time. How would that cause this to happen? I'll uninstall it and see if that helps. Thanks!
    SOLVED. Uninstalling AFE fixed the problem. Thank you PerttiA! I wonder why that would have interfered with other expression content?
    Because the exaggerating dial is on by default
