unable to decode frame
Hi,
i load the video avi format to giroscoping. If the avi is created with carrara i hasn't problem. If i load the avi movie of another sources i have the erroe as title. Why? And think do i do?
    Sounds to me like a codec issue. When I work with video for production use like this, I don't use codecs and just make uncompressed avi (full frames).
    One solution would be to try a video file converter and convert to some codec that is in your list in Carrara's codec list.
    Here are a few: available from C-Net
    Make sure you read on them that they can convert from avi to avi or from avi to "Sequenced Image" formats, which Carrara also supports.
  • ok,
    the solution of convert avi in sequenced image is good!!!
    tnks
