What Would Cause The Selectable Toggle To No Longer Work? SOLVED
gfdamron1gfdamron1 Posts: 269
edited March 21 in New Users
I have a G9F that I can no longer make selectable. The icon next to the eye in the Scene pane always shows an "X" no matter which tool I use. I'm sure it's something I've done but I can't tell what. The problem is only with this particular figure, and has never cropped up before. Normally I would simply delete the character and reload it, but this one is made from a variety of morphs. Is there a way to make it selectable again?
Post edited by gfdamron1 on
  • WendyLuvsCatzWendyLuvsCatz Posts: 38,206
    can you save it as a character preset and load it on a new figure?
    doesn't solve the mystery but could be a workaround
  • ChezjuanChezjuan Posts: 515
    If you haven't already tried it, click the x by the eye and it should turn back to a check. Then you can select the figure. I have occasionally accidentally clicked the check and made the figure unselectable when going to select the node.
  • crosswindcrosswind Posts: 6,947
    And if clicking "X" in Scene pane doesn't work, filter "Selectable" in Parameters pane while selecting the figure, check if it's Locked, then toggle it.
  • gfdamron1gfdamron1 Posts: 269
    Thank you so much for your responses! They've all been helpful.
    I would like to find out more about saving a character as a preset. That sounds like a very useful tool.
    It turns out the solution to this particular problem is as Crosswind described- another aspect of DAZ that I've learned. Btw, it took a few tries to get the Locked setting to stay Unlocked position.
    yes
