Parent items in Place on by default?
StratDragon
Where do I set the parent items to place option in the scene contextual menu to be on by default?
IIRC, it's On by default... even if it's not, you check it to On, and next time you launch DS, it'll be still On as the layout settings are saved each time when you close DS.
Also, you can go to the folder: %appdata%\DAZ 3D\Studio4\. There's a dsx file named "layout.dsx". Open it with Notpad / Notepad++, search ParentInPlace, check if the value is "yes".
