Geting All PINK Renders In Daz 4.20.0.16 PRO
When I go in to Daz studio and hit defult settings and try to rendering an Image using NVIDIA Iray (MDL). I get an all pink render. I've seen other post about this saying you have to add freeimage.dll to DAZ 3D>DAZStudio64>libs>iray but I can't seam to find out on where to go to download this file? Is any one else having the same probblem? What should by defult setings be so I can render? I have an AMD Phenom(th) II X6 1075T Processer 3.00GH with a NIVIDIA GeForce GTX 1050 TI grahpics card.
It should be installed as part of daz Studio, the problem is usually that security sftware has deleted it in error - Kaspersky was prone to that - so check the list of quarantined items in your anti-malware/anti-virus tool.
I've got the same problem. I don't use a virus scanner so, I can't look there. I've tried uninstalling and reinstalling at least 3 times. I've used DIM to do it and I've tried using the system in Win 7 as well. Both ways of uninstalling obviosly don't get everything because, when I restarted Studio, I was at the same place I left off, withe the same tool selected and all.
Any suggestions or information on how to get that little dll back would be appreciated!
Gus
...before you go inserting strange DLLs into your program, check that it is not one of the 'purple' renders that came from one of the Denoiser settings.
I don't think this isn't a denoiser issue. The render is BRIGHT pink. I've never touched any of those settings. If you could give me an idea of where and what to make sure of, I'll check those settings.
I don't want to insert any strange dll into the program, just the one mentioned in the first post. I've checked the dirrectory mentioned and that dll was not there.
Thank you for answering, I appreciate your time.
Gus
My mistake I was thinking of "the Green renders" problem.
