Product does not install
![jodhan322](https://secure.gravatar.com/avatar/39a79f9bba17839e92aee4d949dd58c1?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F39a79f9bba17839e92aee4d949dd58c1_100.png)
I purchased https://www.daz3d.com/pose-architect-for-genesis-8-females, but installing it has failed several times. I've done it through the Daz install tab, and I've used the Daz Installer. Every time I install it, the image is a trangle with an exclmation mark. And it says error when I try and click on the script. I can't find a way to get this working. Anyone else run into issues like this?
Post edited by jodhan322 on
Please use the store link, https://www.daz3d.com/pose-architect-for-genesis-8-females , not the Product Library link as the latter will work only for those who have purchased.
Did you uninstall the product through DS before trying to install through DIM?
I first used the the istall tab in daz studio, then I unistaled it. I then used DIM. Same effect.
Pose Architect is a set of Pose Control dials that you access from the Parameters pane. Please refer to the readme to see instructions for use.
