Ways to add a scene saved by script to the "Open Recent" Menu. [Solved]
![V3Digitimes](https://delorean.daz3d.com/forums/uploads/userpics/651/nMZZ4LL08HIDE.png)
Hello!
I've modified this sript provided by Rob: http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/file_io/save_duf_scene/start for some of my scripts, and my scripts works as intended. BUT the last little touch I would like to add to them is the possiblity to reload the saved scene from the "Open Recent" menu of Daz Studio when scenes are saved by a script, which is presently not the case. For now, the scene saved by script do not appear in this menu.
I don't know at which level this addition to the "open recent" occurs. For now I have found nothing in the "App.getAssetIOMgr()", but maybe this is somewhere else.
I have another solution which would be to locate the AppData/Roaming of users and to "auto edit" via script the "RecentFiles.txt" but I really hesitate doing this... I don't like touching what's in the AppData, and I'm not even sure I'm allowed to do this. :(
Does any one know if it is possible to script the addition of a file to the recent list without scripting the modification of the "RecentFiles.txt", and in this case, can give me some clues to know in which direction I have to look for?
Thanks in advance!
My apologies for not being around much in the last few months to answer questions, I haven't had time for much more than crunching on 4.9 for a while now.
To answer your question... Yes, it is possible to add files to the File > Open Recent menu through script without directly editing the "RecentFiles.txt" file. More specifically, you can use
DzContentMgr::addRecentFile()
like so:This function automatically checks the list of recent files for the file being added (which you can retrieve using
DzContentMgr::getRecentFileList())
, moves the position of a file within the list if it was already there and is being added again, and emits theDzContentMgr::recentFileListChanged()
signal so that any listeners can react accordingly.-Rob
(Yes, I do realize that this post is the only published documentation of this API at the moment. I have been working on a significant update to the Object Index section of the Scripting documentation, which includes this and much more. Unfortunately, due to what I can only surmise was a recent failed Windows Update that corrupted the MBR of the primary drive in one of my home machines and removed files that are critical to the OS, I am currently rebuilding said machine from scratch with new drives—OS, development environment, supporting applications and configurations, etc. Fortunately, after manually rebuilding the MBR on the affected drive, I have been able to recover all of my working files.)
Thank you a lot Rob!!!![yes yes](http://www.daz3d.com/forums/plugins/ckeditor/js/ckeditor/plugins/smiley/images/thumbs_up.png)
I added this to my scripts, and of course, it works perfectly. So the missing line was indeed a kind of an "App.something.dosomething()"...
No worry if sometimes you're not too much available, I know you're very busy!
I'm sorry about your windows udpate issue. Gosh, when things like this occur it is a real nightmare! I'm happy for you you recovered everything.
Thanks for all your help during 2015, and I please take my best wishes for a great 2016 year !!!
