Genesis 9 | Pantyhose | Over Panties NOT Under
![NoahsArt](https://secure.gravatar.com/avatar/4bfd297f66626205e8a2129df94db6a6?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F4bfd297f66626205e8a2129df94db6a6_100.png)
Okay... looking for help. I have tried just about everything I can think of. Geoshell pantyhose keeps going UNDER panties and not OVER. I used to fix this in G8 by using geoshell panties... but there do not appear to be any of those for G9 yet.
Increase the geoshell's mesh offset.
You could create your own geoshell panties.
For using geometry panties and geoshell pantyhose, you will need to increase the offset. But I think you will need to increase it by so much that it will look weird on the legs.
I would suggest using geometry pantyhose, and then use a push modifier with a weightmap to push them above the panties.
The latest version of DS Public Build now supports adding weight map of a Push Modifier on a geoshell node.
https://www.daz3d.com/forums/discussion/comment/8620281/#Comment_8620281
Oh, that is a good start.
But just now I failed to make it work as per the instruction... Pls give it a try.
It will be a nice feature. But I couldn't get it to work.
Yea, thanks ! I also posted the issue to beta thread.
By "geometry pantyhose" I assume you mean... regular .duf non-geoshell?
Yes, because for these you can add a push modifer with a weightmap.
But as Crosswind said, that in the Beta has been included a feature where you can do the same with a geoshell, although none of us could get it to work.
