How to remove gap between eyelash and eye
dan_thomas
I am using G8.1F and found the gaps between eyelashes and eyes. Is there any way to remove or reduce the gaps?
Thanks,
482 x 143 - 166K
Thanks,
More likely the issue came from character head morph(s) that you dialed on this figure. If you zero the head morph dial(s) and the issue's gone, that's it...
Then it'll be a bit cumbersome to make a fix... You just check if that's the culprit as above-mentioned first of all...
I appreciate your reply. You nailed it.
Based on my experiment, I think the problem occurred because I used G8F texture on G8.1F figure. With texture of G8.1F, the problem has gone away.
