Is there a way to force Daz to render the main viewport ?
Hello,
I regurlaly use the Aux viewport to move props and figures inside the field of view of a camera or to move a camera while viewing the result in the main viewport.
Sometime, I forgot to close the Aux viewport, than I hit render and end with a render of the Aux viewport blush
Is there a way to tell Daz to only ever use the main viewport for a render ?
  • crosswindcrosswind Posts: 7,987
    edited March 2024
    DS always render the active Viewport that user select (with a frame in Accent color...). You either click back to main Viewport before rendering or write a script in which you activate main Viewport first of all before starting a render. Then create a custom action for this script + shortcut...
    Post edited by crosswind on
  • ElorElor Posts: 1,944
    Oh, so I just have to make sure that my main viewport is active (by clicking on a object / figure visible inside it) and all will be well smiley
    Thank you yes
    edited March 2024
    Thank you yes
    Yeah ~ but no need to click or select figure / object, just click on any area of the main Viewport, then it'll be active.  smiley
