how to load a morph for v4?
VicS
there is no sliders I can find for imported morphs, thnks for letting me know how it's done
You mean Inject a Head / Body morph from the runtime folder or export OBJ and import OBJ as morph slider with Morph Loader Pro ?
If you mean the latter, you have to first go to : Edit - Figure - Rigging - Convert Figure to Weight Mapping : General Weight Mapping, then export / import OBJ with MLP. You'll find the morph slider under "Morphs/Morph Loader" (the path by default)
thanks crosswind
I meant the latter, with morph loader pro
OK, that'll do.
that was easy, thank you
V4 was edited for wider hips but the morph slider isnt acting right it is as a scale 0-100,
has anyone come across something similar before?
Is it normal to do this during conversion? see image
