Diva's Desire Jewelry Crunched Up
warlordnik
Hey folks, I know this outfit was one of the original Gen 9 releases, but I can't figure out how the jewelry gets crunched up just by loading it onto a Gen 9 character (I'm using Tara 9). It seems to happen on every Gen 9 character. Please see pic.
Both the earrings and necklace as misshapen. But the bracelet and ring are OK.
Is there an easy fix or do I report it as a bug? Thanks very much!
1208 x 1265 - 345K
Post edited by warlordnik on
It is the autogenerated projection morph.
With the necklace selected, you can in parameters enable show hidden, and then click currently used. There will the be a morph named something with Tara, and you can try to dial it down.
A better solution is to take the necklace into a modeller and correct it. But that is more complicated.
Alternatively, don't fit it the Kara, but just parent to the neck. Might need some corrective translations.
Thanks so much, Felis! That parameter trick worked! I learned something new today, even for a 4-year DAZ user!
