Material Copy in daz ?
When I apply content A and click Material Copy to G8F, it works properly.
And than I apply content B and press Material Copy in B ,
and the texture begins to break as shown in the attached screenshot.
I don't know what the reason is or how to fix this problem.
content A is "Golden Palace v2" by Meipe (female genitalia for G8F)
content B is "Breastacular" by Meipe (breast morphs For Genesis 8 Female)
Not only this, but when two or more pieces of content are applied in this way, there are often cases where the material is not copied properly. How do I solve this?
  • Richard HaseltineRichard Haseltine Posts: 102,864
    Please put a bra or swimsuit on the character, the issue would still show.
    I don't have these products but is the script specific to Golden Palace? it could be that it is copying from the wrong area of the map?
  • pctech4nypctech4ny Posts: 184
    edited April 2024
    Since we can't see the exact issue as your post must have showed nudity I am guessing here.
    I think both those products might use geoshell layers?
    Sometimes geografts like those come with "fix scripts" to turn off overlapping parts of the geoshells.
    If there is no fix script in either product, then look up how to turn off some of the individual surfaces of the geoshells.
    Post edited by pctech4ny on
  • FSMCDesignsFSMCDesigns Posts: 12,783
    If you have multiple geoshells, you need to select each one and look for the overlap in the surfaces tab and turn the opacity down on the overlap part. Golden Palace has this issue when used with another geoshell.
  • MaxWellMaxWell Posts: 6
    ty everyone
