installation files
I just purchased Shader Plan Iray Lace and Linen and installed it using DIM. I couldn't find it under shaders so I thought I would download manually and check the file structure in case it installed somewhere else. Opening the downloaded file, I found only suppliment and manifest files.  Does DIM use the same file as the manual download?  Is the product missing files?
  • MelanieLMelanieL Posts: 7,456
    Yes, DIM also uses the tiny 472-byte file. I reported this in the Sales Reporting thread earlier.
  • I tried tto manually download - the prduct zip file is missing ??
    1674 x 292 - 46K
