If I did some pose and I want to load Scene can I combine them both?
foxyfoxfurries
Hi!
I did some pose with model and make a lot of details there , Now I want to load environment but its only have Scene (Holloween Forest).
When I have my model and I click the Scene its delete my character and just give me the Halloween Forst.
Have any option to load it after and make it on the character I already loaded?
If you load a scene it will remove what you have already. You can save your scene as a set, then it will load on top.
Or you could select Merge, but then you have to browse to where your scene is.
Or save your character as a set and then first load the scene and then the set (character).
You can right-click on a scene in a content pane and select Merge (and conversely, for a Scene Subset, you can right-click on it and select Open if you don't want to merge it).
Or... you can hold Alt key first, then drag Halloween Forest (Scene) into Viewport... to where you want it to be.
@Richard Haseltine @crosswind
Thanks to all of you!!!!! :D
