GENESIS 8 FEMALE LOAD WITH STRANGES SHAPES
Hello everyone,
I'm really looking for help, because I'm having a big problem with G8Female.
When I load a base model, or a custom, it arrives with a completely changed and incorrect anatomy, and if I try to apply a morph to it it's even worse!
Here is some example, the first is a basic GENESIS8F, without modification, and you can see that it appears with elf ears and a completely unsightly body shape.
And the second is a morph applied to the model, and as you can see, things are even worse.
( Sorry for the link, i don't know how to put pictues on the discussion )
file:///D:/daz%20ref/lma%20copiefff.jpg
file:///D:/daz%20ref/lma%20copiefffh.jpg
By doing EDIT: FIGURE: ZERO: ZERO FIGURE SHAPE
Nothing happens, no change, whereas before it was at least a backup solution to deal with this problem.
Thank you in advance for your help.
  • Richard HaseltineRichard Haseltine Posts: 102,181
    Your images are not avaiualble as they are links to your own machine. There is an Attach a File link under the text box for replying, click that and then click the Browse button - but please make sure the figure is untextured or the Viewport is in a non textured mode.
    If zero is not working then it may be a hidden proeprty that is causing the issue, or it may be that soemthing has updated the base shape - you can check the latter by reinstalling the Genesis 8 Starter Essentials.
