Kinda Basics... but...
evilded777evilded777 Posts: 2,464
edited April 2024 in Hexagon Discussion
I've got an obj that's a pair of shoes. I'm trying to use Studio/Hexagon bridge to get them to line up with Genesis 8 Male so I can use the Transfer Utility.
Problem is, they are a pair in a single OBJ, so I can't manipulate each shoe into position seperately.
Is there a way to either split these into seperate objects and then re-group them after I have postioned them? Any advice or suggestions appreciated.
I've already done this with a model that was already seperate.
1058 x 691 - 57K
Post edited by evilded777 on
  • Richard HaseltineRichard Haseltine Posts: 102,131
    Can't you just marquee select them and stransform them or cut-and-paste them to a new object layer?
  • FirstBastionFirstBastion Posts: 7,815
    Treat each shoe as its own model, Left and right,
  • evilded777evilded777 Posts: 2,464
    Not sure what you mean here
    Solved the issue by learning to use dformers and weight maps, but thanks for the response.
    I didn't make the model, this is how it came...but I figured a way around it. Thanks for the response.
    marquee select I meant - drag a rectangle out to select all inside it, then transform or cut-and-paste to a new layer the selected bits
