Poser 10 executable file just started crashing on me -- any advice?
Hi all. I have Poser 10 with the latest SR 5.2 installed on my Windows 10 machine. Everything was working fine until yesterday, when I tried to open Poser. I got past the loading screen, but, as soon as the actual GUI was loading, "the Poser 10 executable fille stopped working."
I tried uninstalling programs that were updated since the last time Poser worked, but removing them had no effect. Poser still crashes. Also tried reinstalling the SR 5.2 with the same result. Any thoughts?
--MW
  • WandWWandW Posts: 2,846
    edited December 2015
    Try renaming Poser.ini and LibraryPrefs.ini  (the location depends on your operating system, but in Windows it's in or around C:/users/YOURNAME/App Data/Roaming/Poser/10 and then start Poser and see if it will start....
    Post edited by WandW on
  • Thanks for your comment, WandW. Any tips on how I should rename them?
    --MW
  • adzanadzan Posts: 268
    edited January 2016
    Hi.
    As the crashing started yesterday it sounds like you have the same problem as many of us, it was caused by a Microsoft update patch fix thing for Flash that is causing Poser 10 to crash.
    You will need to uninstall KB3132372 and if you're using Windows 10 Home run the 'Show or Hide update trouble shooter' that you can download from Microsoft, which can be found here - https://support.microsoft.com/en-us/kb/3073930
    There is a thread at runtime dna if you need more details, it's a bit long for me to type it all here lol -  http://forum.runtimedna.com/showthread.php?103122-Poser-Pro-2014-crashes-on-startup
    Post edited by adzan on
  • ModernWizardModernWizard Posts: 851
    edited January 2016
    adzan -- thanks for the tip...checking it out now...
    --MW
    EDIT: It worked! Poser is back! Thanks, adzan! No thanks to you, MicroStinks...
    Post edited by ModernWizard on
    Charles Taylor (nerd3d), the Poser Product Manager posted this over at R'osity.  Unfortunately the fix he cites works only on PP2014, not Poser 10....
    So you all know Smith Micro is in contact with Microsoft on this issue. This is a security patch so if you do remove the patch you need to increase your internet security os require that scripts ask permission before running. That or don't use IE to browse the web.
    If you have Poser Pro 2014 you can switch to the external library. It does not use Flash so it will run. To do this you will have to edit the Poser INI file (Poser Prefs on Mac). Edit the INI file with a text editor (notepad). Don't use Word. This trick only works for Poser Pro. Poser's ini file lives here:
    Windows %AppData%RoamingPoser Pro. Mac HD > Users > (username) > Library > Application Support > Poser Pro > 10
    Look for a line:
    LIBRARY_IS_AIR 0
    Change it to:
    LIBRARY_IS_AIR 1
    Save the file
    Once again we're working with MS for a fix.
    edited January 2016
    Look for a line:
    LIBRARY_IS_AIR 0
    Change it to:
    LIBRARY_IS_AIR 1
    Save the file
    I was also able to run 2014 using the embeded library, which I prefer to the external one, so anyone who doesn't want to remove the Microsoft Flash update could also use that one until Microsoft and SM come up with a fix
    So the change would be as above but change
    LIBRARY_EMBEDDED_TYPE 0
    to
    LIBRARY_EMBEDDED_TYPE 1
  • jimlinjimlin Posts: 146
    flash update which fixes problem now availablefrom  windows update
  • I have poser 10 on windows 10 and I am still not able to use my software and I just bought it.
    I can't get past the load screen with the lady smiling.
    I wish I could at least play around with the morph tool it looks fun.
    If anyone can help I'll so appreciate it ^_^;
