Loosing bookmarks
borisheadmadeborisheadmade Posts: 8
edited April 2024 in Daz Studio Discussion
Hi all
Well i couldnt find anythig related to this thing.
Since big update 4.2x i had many crashes while im trying to use most of OOT hairs.
Daz simply crash, so im not using those hairs anymore or i will in future.....but other thing bothers me along that, as DAZ having heavy  crash i loose all bookmarks made with https://www.daz3d.com/mf-content-bookmarks
so i would like to know, is there any file this product use to write data, so  i could save that file and my precious shortcuts.
Cheers
Post edited by borisheadmade on
  • Richard HaseltineRichard Haseltine Posts: 102,181
    edited April 2024
    Update your OOT hairs - most have a fix for the crashing issue. If it persists (depends on the installation method used, and on whether you have older files in another content directory - the problem data is in a shared file) select the hair in the Scene, then in the Editor tab of the Surfaces pane select the hair on the left, type trans in the filter box, and remove any maps applied to Transmitted colour by clicking the nano thumbnail to the left of the colour control and selecting None.
    As for losing bookmarks, that sounds as if the file that stores its links is geting damaged. I am surprised it always happens, but if you back it up you should be able to restore it - I assume it is in
    %appdata%/daz 3d/studio4/
    somewhere but if you check the vendor's support thread that should give more precise information.
