I'm buying a desktop PC, and these are the specifications it has. How well would Daz3D run?
Desktop PC Core i7, 16GB RAM, 1TB HDD + 240GB SSD, 24" monitor.
  • kyoto kidkyoto kid Posts: 41,198
    edited April 2024
    ...16 GB is pretty minimal.  I have 24 GB and find it limiting.  I would go for at least 32 (if not 64 GB) system RAM, a much larger HDD (2 GB minimum 4 GB preferable) for your Daz content library as they are not that expensive these days.   I would also use an SSD of that size only for the boot and programmes drive.  if you plan to render in Iray, you will need a GPU card, otherwise the process will be glacially slow. I would suggest nothing smaller than 12 GB of VRAM (RTX 3060 - around 280 USD) 16 preferable.(RTX 4060 Ti  - around 450 USD).
    Post edited by kyoto kid on
    edited April 2024
    Current, in practice minimum requirements for Daz Studio at the moment; An nVidia RTX GPU with the very minimum 8GB's of VRAM (memory on card), minimum 12GB's of VRAM recomended, minimum 32GB's of RAM and a separate min 2TB storage drive for the content library.
    The PSU (power supply unit) needs to be big enough to drive the GPU and installed components. A good quality 750W goes a long way.
    The rest doesn't matter that much.
    Post edited by PerttiA on
  • FirstBastionFirstBastion Posts: 7,822
    It does depend which version of Daz Studio you are running.  DS 4.10 needs less ram (16gigs) than 4.22 which needs more. (32-64 gigs)
    The RTX nvidia card will matter too. If you can find a system with a RTX 3060
  • PitmaticPitmatic Posts: 917
    This is a whole can of worms
    The graphics card will be doing your rendering and you have not specified one
    I was running a 3rd gen I7 with 16GB ram and a GTX1050 (in othewords the cpu did everything) it would run 4.22 just fine it all depends on what your doing but it was slow
    Now I have a 13th gen I5, RTX3060 12gb and 32gb of ram 1tb ssd running windows and apps 2tb ssd for daz assets only using 25% of it so far and then i have 3 x 4TB external HDD's holding my work and 2 backups
    compared to the old system the new one is about 6 to 8x faster ish depending on what your doing but even so it has on occasion locked up with daz doing silly things
    The graphics card has run out of memory once or twice and the ram was exceed once i think but it all came down to the assets being used in combination but i do simple scenes your milage will vary.
  • 16gb RAM is the first blockage. Try 32 or 64.
    The HDD can be upgraded later. You do need an nVidia GPU, and an RTX 3060 seems the most cost effective at the moment. But the RAM is more important. I found when I had a 16gb machine that when Windows tried to use page files instead of RAM, DS just departed. Furthermore, when starting to render with or without a GPU your RAM usage ends up being the DAZ Scene RAM usage + 2Gb per G8 + 2Gb for a simple background. G9 seems to me to take 2.5Gb per character as an average. Not sure why the increase is there. Anyway, the 'preparation to render' phase seems to use most RAM, and 16Gb may be OK for a scene with up to 4 characters.
    Regards,
    Richard
  • Ghosty12Ghosty12 Posts: 2,064
    edited April 2024
    Yup if you can afford more ram the better, and would want a decent nVidia GPU with the 3060 12GB model being very good.
    Post edited by Ghosty12 on
  • Matt_CastleMatt_Castle Posts: 2,644
    Like others here, the least I would recommend for a DS system is 32 GBs of system RAM with an RTX 3060 12GB GPU (And yes, it does need to be the 3060, not the 3060 Ti, as the Ti variant has less VRAM).
    While less than that is theoretically usable, it's quite limiting and I wouldn't be able to call it a good choice.
  • dark_night_cpdark_night_cp Posts: 3
    edited April 2024
    It doesn't come with a GPU included, but I plan to buy one RTX 3050 8GB. i have a question, could I use the 16GB RAM for rendering in Daz3D if I specifically use 3Delight?
    Post edited by dark_night_cp on
  • I plan to use Daz3d for drawing reference. The scenes I would create would mostly involve only three characters at most, or just one.
  • cjfeacjfea Posts: 245
    edited April 2024
    Hello.  I have been running Daz on an i7, 16 GB RAM, and and 1650 Super (4 GB) for almost 3 years.  Honestly, I would not recommend it.  I would follow the suggestions already offered (a minimum of 32 GB of RAM, an NVIDIA card with 12 GB of VRAM if at all possible and ideally 16 GB of VRAM).  Although GPU VRAM usage varies for each render, and some factors can be altered to reduce VRAM use, this video might be useful to consider:  Daz 3D : How Many Genesis 8 Models Fit On A RTX 3090? (youtube.com).  I hope you can find a suitable computer and will join our commnity.  Bests always.
    Post edited by cjfea on
    edited April 2024
    ...If you are looking to use 3DL (or Carrara): system memory and CPU core count become even more important. While setting up scenes Daz only uses a single CPU core, however  3DL and teh Carrara render engines will use as manythreads  as you can throw at when rendering.  If that is what you are looking at I'd go with an AMD Ryzen CPU  as you can get more fast processor threads for the money than with Intel since the latter has gone to a CPU architecture that splits the i7/i9 CPU cores between efficiency (slower single threaded) and Power (faster dual threaded).cores.  For example an 8 core CPU will have 6 dual threaded and 2 single thread ores for a total of 14 instead of 16 threads.
    Also for Iray rendering keep in mind that Windows WDDM in 10 & 11 reserves about 1 GB of VRAM for its own purposes and there is no way around it.  So that 12 GB GPU actually has around 11 GB available for rendering.. The best way to go if you can afford it is a lower VRAM GPU to drive the display(s)  (or a CPU with built in graphics) and a higher VRAM one that is reserved just for rendering (not hooked up to the displays. (however this will slightly affect the response when using Iray view mode.
    Again it all depends on the complexity of the scenes you plan to create.
    I tend to go with fairly "heavy" scenes with a lot of figures, items and effects. as well as higher render quality and larger render formats.  If you are just doing portraits or single character/simple scenes, 12 GB of VRAM (and for 3DL a 12 core/24 thread Ryzen) should be more than enough.  If you are looking at using 3DL on a regular basis I would check out Wowie's AweShading kit (available at the other store, so apologies, no link) which can produce near Iray like quality  As most priducts today are created using only Iray shaders you will need this script: to help with conversion.
    https://www.daz3d.com/rssy-iray-to-3delight-converter-and-merchant-resource
    Here is a thread to see some of the results,  In particular check out hte images by Sven Dullah as he uses the AweShader..
    https://www.daz3d.com/forums/discussion/514336/show-us-more-of-your-3delight-renders/p1 ;
  • butterflyfishbutterflyfish Posts: 1,267
    I've got the RTX 3050 8 GB. If you truly can't afford the 3060 12 GB, and you don't mind having to optimize sometimes, it's adequate. the 3060 would be better, but money is a thing. Good luck.
  • leo04leo04 Posts: 341
    Would an Xeon processer be a good choice for the PC?
    I get the rest...just curious what the concensus is.
    Thanks.
    ...I've been running with a Xeon (albeit an older 6 core/12 thread) for years and had no issues.   As Xeons are geared more for use in servers and workstations they don't include integrated graphics  ike some Intel i7/i9 or AMD Ryzen CPUs. However as you are likely working with Iray in Daz and have a dedicated GPU  that is something of a moot point.
  • ArtAngelArtAngel Posts: 1,782
    Good advice here. If I were buying a new rig, I'd wait to see what DAZ 5 brings to the table. So far, since 2017, the only thing I would have done differently is started out with assets on external vs internal drives (and used the Geometry editor more). I prefer to render toons/stylized/NPR than PR but I do it in IRAY. On the odd occasions I use Open GL for 3Delight and it renders in the blink of an eye. Some people complain about rendering several characters in a large scene, so I was nervous about installing 4.21 PRO and 4.22 PRO. Although DAZ studio has compression set at 512 as the default, I've changed mine to 6100 and also 8100 and render 5000 iterations in a 5700 plus pixel scene to avoid pixilation in graphic prints. I am able to render a large scene that includes seven characters, a blend of 8s, 8.1 & 9s fully dressed, hair, hats, a couple of beards, large amounts of snow and buildings, oodles of decals and custom textures, with dForced assets simulated. That scene rendered in 36 minutes to 1 hour on 4.21 and 4.22 (found 4.21 faster). And that same scene, same render settings, rendered in 11.5 minutes in DAZ version 4.15. My machine is old now. Got it in 2017 but the x299 chip was brand new on the market. and ended up to be a great choice. The system I use the most that does those fast renders, where none of the DAZ studio versions ever crashes, is Rig1. I call it ODIN lol.
    Rig1: i9-9980XE CPU (18 cores 36 Threads) MEG X299 (MS7c06) 128GB RIPJAWS RAM Dual RTX 2080ti (11GB and 4352 CUDA Cores each) and a NVLINK which works for me in DAZ Studio according to the log files. It has a EVGA Supernova 1600 P2 Platinum power supply.. 750 was not near enough. This system is water cooled with copper system.
    Rig2 I use for large scenes as well but Rig 1 is faster.
    Rig2: i7-7700K CPU (4 cores) STRIX Z270E 64GB RIPJAWS RAM Dual GTX1080ti with SLI, CUDA Cores 3,584 each. DAZ Studio does not render with both 1080tis cards. It has a EVGA supernova 1000 PA platinum power supply. This machine has 7 fans and a good cooling system, but is not water cooled. I have rendered on this machine so much the CPU fan was whining just went last week and I had to shut it down until my computer guy came over and replaced it. I had both machines custom built by my local computer guy. I original had a system built by Falcon (dual Pascal Titans) but shipping it back and force was a pain. And it shipped 4 times in that first year.
    Both machines have Samsung SSD 2 TB internal hard drives, but I own a couple of dozen external SSDs mostly 4TB but 4 are 8TB. I was a big fan of Samsung but find the Crucial brand performs better and never get hot. I use dim to download and only download DAZ purchases. A while back I ran out of space on the 2TB and moved downloads to an external 4TB SSD but now it's in the red zone. Same with installed files. I never delete downloads and I always manually download products with screenshots and keep those on my own custom DAM system.
  • MasterstrokeMasterstroke Posts: 2,032
    edited October 2024
    Only a few rules for a system, if DAZ studio is your main app:
    -Best Nvidea GPU you can afford
    -Best CPU you can afford
    -Get the most RAM and VRAM you can afford
    -No MAC !
    -No AMD GPU !
    Post edited by Masterstroke on
    ...and don't scrimp on the power supply as the PSU as that is essentially the "heart" of the system.  It is always good to have  abit of "overhead" for later upgrades.
  • oddboboddbob Posts: 402
    The first I7 cpus are about 15 years old now. If the vendor doesn't specify the model then assume it's on the older side. Also assume that everything else in the system is going to be of a similar level.
  • I did manage to find a 4060 with 16GB of Ram on it. Was only 450 at the time.  The more system RAM the better too. And BIG HDD's if you are going to have a lot of assets/projects.
