Clothes problem
I'm having a recurring problem with shirt, coats,etc. When the character moves the edge on part of the clothing puffs in and out. I fit the clothes to the character and have made adjustments with mesh smoothing, push modifers, etc. but the problem keeps cropping up. I have attached a screen grab. Note the character's left sleeve in the center. Those abnormailites flicker on and off/ This doesn't happen all the time but enought to be really annoying. I've searched for any similar problems but I haven't seen any. I'm hoping I can get some advice here.
749 x 398 - 313K
  • MadaMada Posts: 1,991
    Its when the character mesh intersects and the clothing item smooths to the outside of the arm instead of to the body. Adjust the shoulder bend to be less extreme - more space between the arm and the chest. Or turn smoothing on the clothing item off.
  • Richard HaseltineRichard Haseltine Posts: 101,010
    Or use a dForm or negative push modifier, probably weightmapped, to open up a gap on the inside of the bend so that there is space for the clothing.
  • Thank you.  I'll try that!
