trying to find DS Defaults in shader presets
![VicS](https://delorean.daz3d.com/forums/uploads/userpics/054/n3BXRE0E57XKV.png)
I am trying to put v4 skin onto g8f, all I need to do is
select all of the surfaces of the figure and go to: Shader Presets > DS Defaults, and double-click "dzDefault", which will make them all 3DL based shaders.
The thing is when I select the skin I cannot locate anywhere where it says DS Defaults/dzDefault under the shader preset tab
Post edited by VicS on
In Smart Content mine is in Default > Shaders > 3Delight > Other
What have you selected in Scene and Surfaces?
I have g8f selected after I have put 4 skin on her, the next step according to Dartanback is to simply get that skin material to not be pbr and that he says is done with
DS Defaults, and double-click "dzDefault", do you see those two terms in samrt content?
I am not sure if "DS defaults" is a folder or what.
I am just searching for "dzdefaults" in Shaders.
yeah I searched and searched
The presets tab of the Surfaces pane filters by context, by default, meaning you need to select at least one surface for the Shader Presets to show.
just heard from him, turns out it is in the content library
I was able to put the g4 skin onto g8 but here is the result, on the left in 3DL
repeat message by mistake
Please put some clothes on them, such as the Basic Wear top and briefs.
ok sorry
