i want to color effect but i can't.
coolcool0131_eea6a807
I bought sci-fi effect and loaded it into daz3d. On the pre-render, the colors that work well come out, but on the renders, all the effects come out in black.
Which effect? Is it made for the render engine you are using - Iray, 3Delight, Filament?
Is this the product you're talking about? https://www.daz3d.com/iray-scifi-vfx-kit
It's hard to offer any help without more information
You need to set the Diffuse colour to white, Poser doesn't multiply the ambient colour by the diffuse (so it can be used as a glow) but DS does, or Delight does (so it behaves as a cheap way to have a genral lighting, without having to use an environment map). This is likely to be an issue with all effects that pre-date Iray (usally an SKU lower than 20,000 or so).
oh! laser is perfectly done! thank you for help
