DS 4.22 - can't find GoZ
info_b492a00165info_b492a00165 Posts: 167
edited May 2024 in The Commons
So I tried using export to zbrush for the first time in a while.  It wasn't there.  So used download manager to redownload it.  No matter what I do it won't show up in Installed plugins.  Is this fixable?
  • Richard HaseltineRichard Haseltine Posts: 102,716
    Make sure you are using the right release channel (gebneral reelase or Public Build/beta) - there can be only one GoZ installed, so getting the wrong one will remove the right one. Also make sure that the versions match  - a freshly downloaded goZ will work only with the current build of that release channel.
  • Thank you.  Will give it a go tomorrow.
  • Could you please post links to the different versions of Go z?  When I search for it nothing comes up.
    They are different isntallers for the same product - the beta will haev a PB tag next to its name in DIM, and will have Public Build appended to its name - assumign you have the DS beta, and have enabled DIM to show betas.
  • So I search for public build and found them.  Installed them still no Go Z.
    Here's what is installed.
    1510 x 288 - 81K
  • frank0314frank0314 Posts: 14,298
    edited May 2024
    GoZ has its own installer. Did you also reintall that, just to be sure after you updated DS? Do you have ZBrush mapped within DIM?
    Post edited by frank0314 on
  • I updated both in the image.  Go z isn't showing up in the applications.
    1556 x 651 - 153K
