Genesis 9 Makeup scripts fail with specific character materials as base
![clerian](https://secure.gravatar.com/avatar/804438ca7735ebd0211c738419dddda0?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F804438ca7735ebd0211c738419dddda0_100.png)
I am running into two separate issues with Genesis 9's makeup scripts.
1) After loading Xi Yue's base materials, any Genesis 9 makeup scripts outright fail to load with the error message "An error occurred while reading the file, see the log for details" with the following log output:
2024-05-16 19:33:15.506 [INFO] :: Loading script: D:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/people/genesis 9/characters/daz originals/olympia 9 hd/materials/makeup/olympia 9 makeup apply 05 eyeshadow.dse2024-05-16 19:33:15.509 [DEBUG] :: Adding Layer To Existing Layered Image2024-05-16 19:33:15.509 [DEBUG] :: Found Background Layer2024-05-16 19:33:15.510 [DEBUG] :: Adding Layer To Existing Layered Image2024-05-16 19:33:15.510 [DEBUG] :: Need to create Background Layer2024-05-16 19:33:15.511 [DEBUG] :: sImage2024-05-16 19:33:15.511 [DEBUG] :: Converting Existing Layer To Layered Image2024-05-16 19:33:15.595 [WARNING] :: Script Error: Line 602024-05-16 19:33:15.595 [WARNING] :: Error: cannot access member `name' of deleted QObject2024-05-16 19:33:15.596 [WARNING] :: Stack Trace: <anonymous>()@D:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/people/genesis 9/characters/daz originals/olympia 9 hd/materials/makeup/olympia 9 makeup apply 05 eyeshadow.dse:602024-05-16 19:33:15.596 [INFO] :: Error in script execution: D:/Daz 3D/Applications/Data/DAZ 3D/My DAZ 3D Library/people/genesis 9/characters/daz originals/olympia 9 hd/materials/makeup/olympia 9 makeup apply 05 eyeshadow.dse2024-05-16 19:33:15.753 [INFO] :: Loaded image: Xi Yue1001 Lip 04A.jpg2024-05-16 19:33:16.336 [INFO] :: Saved image: D:\Daz 3D\Applications\Data\DAZ 3D\\DAZStudio4 Temp\d70_Makeup Weight.png2024-05-16 19:33:21.090 [INFO] :: Saved image: D:\Daz 3D\Applications\Data\DAZ 3D\\DAZStudio4 Temp\d68_Makeup Metallicity 2.png2024-05-16 19:33:21.624 [INFO] :: Saved image: D:\Daz 3D\Applications\Data\DAZ 3D\\DAZStudio4 Temp\d69_Metallic Flakes Weight 2.png
2) After loading Xiao Hua's base materials, running any makeup scripts causes the base materials to unload and the Genesis 9 model is left with a white base skin under the makeup.
EDIT: Apologies for the log file output, but for some reason the preview shows it on multiple lines but the actual post shows it compressed on a single line.
Post edited by clerian on
