Side panes obscure cube and other scene controls
cheard
This is on Windows, using the City Limits workspace layout preset. When I open a pane on just one side or the other of the screen, the viewport resizes/repositions and all is well. If I open panes on both sides, though, the panes on the right overlap the viewport and I can no longer see the cube tool, the framing tool, etc. -- all the scene/view tools that sit in the upper right-hand corner of the viewport. Please see attached screenshot, which may show it better than I can explain it in words.
Does anybody know of a way to mitigate this problem (other than getting a bigger screen, LOL)?
Gratefully,
Chris
1600 x 853 - 141K
Close the Shader panes - and possibly the Script IDE. Their minimum widths are wider than the available dock area. Alternatively collapse the right pr left pane groups by clicking on the tab of oen of the active panes (the one that is showing its content in each group).
Closing the Shader Mixer pane did the trick! Thanks!
Actually it might have been enough to close the Brickyard section to the elft of the pane, with the list of bricks that can be added to a shader network - if you wanted to use the pane you coudl still use the right-click menu to add bricks.
