Diffeo - Problem with ERC and G9, both new and old method
dmnmf
Hello,
I'm importing G9 unbaked, load all the stuff, load the Nina9 head custom morph, yet the position of the eyes is wrong when i dial it in, with ERC in global settings set to translation (new method) and armature and then "morph armature" (old method).
I think i narrowed the culprit down to the "proportion head size" morph not moving the eyes (note the difference between armature and eyes). The "proportion head size" morph seems to be part of the nina9 morph?!?
I added the baked imported Nina to the image for reference. Any ideas?
1371 x 632 - 994K
Post edited by dmnmf on
You need to update to importer 4.1 then select "ERC by armature all" in the global settings, this way "proportion head size" works fine. Another way is to use "ERC by translation" with "import dbz morphs" in advanced setup.
https://bitbucket.org/Diffeomorphic/import_daz/wiki/Advanced/Morphs/Import DBZ Morphs
Thank you so much, the update did the trick. I had to set ERC Morphs to Translation in global settings though.
