Flipmode IRAY Skydomes Turn Scenes Hot Pink (Solution found)
I went back to render an old image, and find that anything I created using any of the Flipmode Iray Skydome products, now turn the entire scene Hot Pink...
It seems to be a problem in 4.22 as it does not happen in 4.11 pro. It seems that .exr files are broken...
Updated: I have found...that you can get past this by converting the exr file to an .HDR file in photoshop... Then it works again...
JD
Post edited by jdavison67 on
Several of the Flipmode products have been updated to address this issue. If you download and install them again, it might address the issue for anything you might not have converted yet.
Thanks! I didn't see any updates in my download manager... but I'll check again...
JD
