change the path of several Morphs at the same time in parameter settings?
![food.plus13](https://secure.gravatar.com/avatar/3cce57c5cadefc83767912b34efecd75?&r=pg&s=100&d=https%3A%2F%2Fvanillicon.com%2F3cce57c5cadefc83767912b34efecd75_100.png)
Hello everyone
Do you know if it is possible to change the path of several Morph at the same time in parameter settings?
I have several dozen Morph to transfer to another folder but doing it one by one makes me lose a lot of time...
Thank you
Which path...? the path in Parameter Settings or the path (folders on your disk) where morph files (DSF) locate ? They're different things.
If you mean the former, turn on Edit Mode in Parameters pane, multi-select the morphs, in RMB menu : Set - Property Group.
If you mean the latter, just physically move the DSF files from current folder to the destination folder. F2 - Clear DSON Cache. Then reload Genesis figure.
Thank you very much, I was talking about the 1st case... until now I did it one by one... it's crazy!
For the physical folders I don't really understand... do I have to press the F2 key? I always thought that to change the physical folder I had to save the Morphs in another folder.
When I do F2 I have this window and I can't find "DSON Cache"
That is the scripting pane - you need the main window's Edit>Preferences.
Perfect thank you very much
