Female warrior muscle
xavieratorxavierator Posts: 155
edited June 2024 in The Commons
Dear,
Can I get a similar base as attached image using "Genesis 9 female" and adding this reference ?
https://www.daz3d.com/massive-morphs-for-genesis-9
I mean getting more marked muscles than using only the basic female, especially the biceps.
Thanks, Xavi
966 x 628 - 108K
Post edited by xavierator on
  • ElorElor Posts: 1,760
    I don't have the product so no idea (even if there is no reason for it not to work on Base Femine).
    @RawArt created a support thread for that product and is regurlarly active on the forum:
    https://www.daz3d.com/forums/discussion/625646/
  • RawArtRawArt Posts: 5,923
    You can use the massive morph set for that...it can add just muscle definition if you want, or you can dial up the muscles as big as you want.
    The only thing to keep in mind is that this works full body and is not broken down into individual muscle groups, there are other sets that do that, mine is made for quick and simple bulking up
  • OrangeFalconOrangeFalcon Posts: 250
    This is a pretty good product.  Here's some examples of Jenni 9 with the female morphs included.  Her base form, then with the massive muscle morph, then with the bodybuilder and then female hero (with also muscle added).
    The Hero will increase height, hands and feet, too. Now THAT's a hero!
    877 x 914 - 149K
    877 x 914 - 155K
    877 x 914 - 153K
    877 x 914 - 160K
  • xavieratorxavierator Posts: 155
    Perfect, I will try the RawArt reference soon.
    Thanks, Xavi
  • sunnyjeisunnyjei Posts: 502
    Not sure if you are interested in other options too if so Freja 9 and 9 has a bulk option that seems a bit more like the 3d figure you posted
    I've personally had a lot of luck using Freja 8 and 9 for bulking up characters along with https://www.daz3d.com/sy-intense-muscle-genesis-8-81-and-9 . Using Freja 9 and the other I mentioned I created a character almost as buff as the one in your image fairly easily.
    And Freja 8 plus another buff female asian daz original character whose name I am forgetting for this one: (You mentioned Gen9 and since Freja works for both thought I would show Freja's bulk dialed in a bit more than my Gen9 character above)
    Good luck with whatever assets you end up getting. There are so many good ones for dialing in that I hope you get one that works for what you need :)
    2180 x 1010 - 3M
    edited July 2024
    Dear,
    I just check Freja 8 (https://www.daz3d.com/freja-8), and I would like to know the meaning of this term:
    • Muscle contraction added
      • Major muscle groups now automatically contract with natural movement and posing of figures.
    In fact, I don't need an extra muscles, for this bust, I only need to enhanced a little bit the biceps, without exaggerating or showing the veins.
    Do you think that I can get this needs only with Freja 8 an it's "muscle contraction added" ?
    https://www.daz3d.com/cdn-cgi/image/width=200,height=200,fit=cover/https://gcdn.daz3d.com/p/73503/i/freja-8-01-daz3d.jpg
    My mission is to print a 3D bust.
    Thanks
  • Matt_CastleMatt_Castle Posts: 2,617
    Muscle flexing is a standard feature of Genesis 8. I do not believe that Freja has any additional capabilities in this respect.
  • GordigGordig Posts: 10,118
    Muscle flexing is NOT a standard feature of G8; JCMs make bends look more natural and realistic. There are many products that can add musculature and flexion morphs.
    edited July 2024
    While comparatively basic, the Base Flexions controller on Genesis 8 is a standard feature that did not exist on Genesis 3. Check the file path of the controller in its properties - it's found in the Base folder.
    The text being referenced exists on all G8 core characters, right back to Victoria 8: https://www.daz3d.com/victoria-8
    Post edited by Matt_Castle on
    Freja 9 has a great buff build, and it looks like she was specifically designed for that viking look and style (as evidenced by her bundles).  However, don't discount Kara 9's, Cheyenne 9's and Zahara 9's buff builds!
    1650 x 1670 - 866K
